1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Im looking to go from a TBI to a carb in my 89 d100. what I need to know is what size would work best for a daily driver, and what is involved in the swap.
thanks in advance anyone who decides to help =]
you would need a different wiring harness under the hood, fuel pressure regulator, distributor and coil. i think you might be able to use the same intake manifold as the TBI. there might be more thing but i can't think of them right now. the stock 2 barrel holly carbs are nice.
thanks. I guess Ill just wait till its 25 years old and rebuild it without all the emissions garbage to make it easier. I plan on going nuts, everything mechanical like all trucks should be
