Grounds
Grounds
I have been having electrical problems with my truck pretty much since I bought it. I was working on it with my mechanic friend and he said that all trucks as old as mine have had 3 grounds on it. 1 from the battery to the body, 1 from the battery to the engine, and on from the engine to the chassis/body. He is a Master Technician for GM and did say he wasn't familar with Dodge so I just want some input before I add another ground. Anything to make my life a little easier would be great.
Welcome to the club. Anyone with an older vehicle that has not had electrical problems is either a new owner or a fibber. Bad grounds are very common on these trucks and often the cause of much hair pulling. The battery, engine, frame, cab, and bed should all be grounded together. The manner/order that this is done varies and is not as important as the fact that it must be accomplished. If you have specific questions the going rate is as follows.
opinions are free
answers are inexpensive
correct answers are priceless
opinions are free
Personally, I don't like using an exhaust bolt as a ground although everyone seems to use them for this purpose. I prefer to use an unused taped hole in the block or just about any other existing bolt. Exhaust manifolds and bolts are always the rustiest on an engine and lead to bad grounds in the future. JMHO
