Oil and valves
Old Dec 7, 2010 | 04:12 PM
saints_fan77's Avatar
saints_fan77
Default Oil and valves
I have a 93 w 150 with a 318. ITs starting to get pretty cold out so im thinking of a oil change. What weight does everyone suggest for my truck. A few days ago i noticed this sound coming form the motor it kinda sounds like a exhaust leak but it stops when the truck gets warm. im thinking it may be a valve although it doesn't really sound like one. Is a small valve tick or float common in these motors?
Old Dec 7, 2010 | 04:24 PM
crazzywolfie's Avatar
crazzywolfie
i use 5w30 in my engines but it is my preference.
Old Dec 7, 2010 | 10:19 PM
Gerehead8's Avatar
Gerehead8
Probably is an exhaust leak. The metal exhaust pipes expand as they get warmer. My '94 used to do the same thing before the exhaust was welded.
If it was a valve you would have bigger problems. Valves don't usually "tick", it tends to be other components like lifters (common, not a problem). You would only exerience valve float if revving the motor way past redline.
Old Dec 8, 2010 | 12:59 AM
saints_fan77
alright well i will do a oil change to a synthetic 5w 30, and look for some exhaust leaks
Old Dec 8, 2010 | 04:04 AM
pickfiddle's Avatar
pickfiddle
5w30 is perfect for temps ranging from 100+ to about 30 below. But why bother with switching to a synthetic??
Old Dec 8, 2010 | 03:05 PM
saints_fan77
well i live in michigan and temp are around zero degrees. For the synthetic my granddad used to be a amsoil dealer and i have tons of it sitting around
