W150 Front end
W150 Front end
I have a 1990 Dodge W150, the previous owner changed the front axles with from a doner Ramcharger. come to find out the first time I use 4 wheel drive the front end is a different gear ratio. I do not know the ratio but in the snow I can feel the rear end spinning faster making the rear slide, and on the dry concrete the front and the rear are fighting each other. Any way I got a buid sheet for the truck and it says it has a 3:55 ratio in the rear, I have searched the internet and I can only find 3:54 for the dana 44. Also would the front be a revers cut in the front? Also I did find one site that had the 3:55 but they refer to it as a large pinion. The build sheet says the truck came with a DJCS 195mm Front Axle. Is the 3:54 the correct one?
On most of the 4x4 trucks you will find that the front diff is not the same as the rear ratio(3:55 rear/3:54 front 4:10 frt/4:11 rear). You just would not want to go to a 3:55 rear and a 3:21 front it just will not work.Also if you do try to lock the truck in 4wd on dry pavment and try to turn the steering the truck will feel like it is walking(it is really bad on the drivetrain) so I really don't advise doing this you might tear a front axle out or break a transfer Case.If you do want to lock the truck in 4wd try to lock it in on dirt or sand or snow,but a dry road just tries to lock everything up
