I have two 1990 ram 150 with 318 parts trucks
i just thought i would point out the guy has not even logged in in about a year.
finding a turn signal switch should be easy at any junk yard. 91-2001 dodge rams used the same turn signal switch. i think the only thing i noticed is that almost all the newer trucks had delayed wipers. now if your truck does not have the option now may be a good time to ad it.
Dang! I really need to start looking at dates! I just assumed that since this thread showed up it was recent....thanks for pointing that out. I am going to junk yard a TSS. So is the delay built into the switch? Mine has intermittent wipers, wash, and turn on it.....it is a 1991 Power Ram 150 4x4...
no. there is a delay module under the dash. if your truck has intermittent wipers you should not have anything to worry about. the only thing i forgot to mention is that you will need a t20 security torques bit to remove the switch. you will also need a t20 torques screw driver to remove the plastic around the steering column and the tilt steering leaver on newer trucks just unscrews like a bolt but might be stiff and require pliers to turn. before you go to the junk yard you could take the plastic off your steering column to make sure you have all the correct tools to do the job.
