overheating
Old Jan 14, 2011 | 09:56 PM
shortwide84's Avatar
shortwide84
Default overheating
brand spanking new water pump and 195 thermostat.... still overheating. i flushed everything during instulation. please give me some ideas to try.
Old Jan 14, 2011 | 10:09 PM
rocketvette95's Avatar
rocketvette95
Radiator could be stopped up.Thermostat could be stuck closed.A radiator hose could be sucked closed.And the fan clutch could be inop not drawing enough air.
Old Jan 14, 2011 | 10:12 PM
shortwide84
can i get the radiator boiled or something? a new one is $120 and that is the cheap one.
new thermostat
will replace upper/lower hoses and clutch fan tomorrow
Old Jan 14, 2011 | 10:20 PM
shortwide84
the heat wouldn't work tonight, but it did last week when i first swapped the pump and done the flush
whats the difference between the thermal and non-thermal fan clutch?
Old Jan 14, 2011 | 10:27 PM
rocketvette95
The Thermal clutch will basiclly freewheel when the water pump snout gets to a certian temp,this is what is normally installed from the Factory.But before I would go out and buy this stuff,I would check with one of the local Radiator Shops and see what they charge for checking the radiator core to see if it is stopped up.
Old Jan 14, 2011 | 10:45 PM
crazzywolfie's Avatar
crazzywolfie
thermostat may be sticking or could be the fact that you used a 195 and not a 180.
Old Jan 15, 2011 | 12:37 AM
pickfiddle's Avatar
pickfiddle
I agree with crazzywolfie. I'm almost positive that it should be a 180 degree thermostat.
Old Jan 15, 2011 | 01:28 AM
shortwide84
i've had a 195 in the truck for almost a year now, just put a new one in for good measure
Old Jan 15, 2011 | 02:01 AM
crazzywolfie
maybe the new one is sticking or defective. the easiest way to tell is feel the top rad hose when the gauge is reading hot. if it is cool i would say you have a bad thermostat.
Old Jan 15, 2011 | 02:11 AM
shortwide84
it is the fail proof thermostat, ya never know though
the more ideas i get tonight, the more information i'll have for ya'll tomorrow night. i know the radiator was in bad shape. i flushed it in early spring 2010 and again the other day but it probably needs serviced at a shop
