headlight question
Old Feb 25, 2011 | 12:13 PM
shadowdragon's Avatar
shadowdragon
Default headlight question
ok well in my test drive last night i discovered that my driver side headlight isnt as bright as my passanger side and if i put the high beams on the driver side goes almost completly out and the passaanger side goes to high beams no problems, so anyone else here thinking bad conection or wire ? i havent had time to check the wires but wanted to post and see if someone else has had this issue. thanks
Old Feb 25, 2011 | 12:23 PM
crazzywolfie's Avatar
crazzywolfie
sounds like you you might have a bad ground on the drivers side.
Old Feb 25, 2011 | 12:52 PM
SEAL's Avatar
SEAL
Check the light socket and bulb for corrosion.
