318 heads on a 360
HEY ive heard putting 318 magnum heads on my 360 magnum engine would give me a slight power increase, i know the 318 has a 9.1:1 compression ratio and the 360 has a 8.9:1 compression ratio, so will it give significant power increase
there is so much different info on that website for so many different versions of the same engines that it would be hard to tell if that info applies to you truck. i know the stroke on a 360 is suppose to be greater than the 318 which would leave me to believe the compression ratio to be more
i think you might be looking at information on the LA series small blocks 273-318-340-360
and on those engines it might make a difference but requires intake from a 273-318 also if you do it ...and its not worth it in my opinion...the loss of flow from the smaller intake/exhaust ports ....you would be better off having a machine shop deck the heads...make sure they deck the intake side to the correct ratio so your intake will fit back on correctly
