Exhaust
Old Mar 19, 2011 | 02:32 PM
RamKing's Avatar
RamKing
Default Exhaust
So i got flowtech headers for my truck and i was wondering what mufflers i should use? What size pipe should i use? im doing a daul setup. Anybody here do an exhaust for their truck?
Old Mar 19, 2011 | 04:56 PM
crazzywolfie's Avatar
crazzywolfie
most people don't like running duals on there truck because of where the plastic gas tank is located. i don't even know of a shops that would not even attempt to install dual exhausts on these trucks because of where the gas tank is.
Old Mar 19, 2011 | 05:41 PM
charlie1935's Avatar
charlie1935
Run them out the same side as in the SRT 10 or cross one over at the rear axle like most cat back kits.
For a stock or nearly stock 318 I'd use 2 1/4", 360 2 1/2".
Old Mar 19, 2011 | 10:31 PM
slicedtomatoes's Avatar
slicedtomatoes
are your flow tech headers full length headers or shorties....on my 78 ram 4x4 i did full length headers(i dont remeber the manufacture..was quite a while ago i did this) and pretty much straight 2 1/2 inch pipes...i had an exhaust shop put about a 3 inch offset bend in them to avoid the transfer case cross member and they stoped just in front of the rear wheels with angle down exits on the end of the mufflers....and i just used some cheap mufflers from summit.....if i had to do it again though i would get stainless steel vs aluminized pipes and mufflers though as i live in minnesota and they rusted out pretty quick and i should have put an h or x pipe in there...but the truck ran good without one
Old Mar 20, 2011 | 01:15 AM
RamKing's Avatar
RamKing
crazzywolfie
im installing them my self at my shop i got and running them down the passenger side
charlie1935
Running them down one side sounds most logical to me cause of the gas tank and ill have the the exhaust come out in fornt of the back wheel, i would probably use 2 1/2'' that what most people say to use
slicedtomatoes
they are long tube, the shorties were about 300$ the flowtech were under 200$
Old Mar 20, 2011 | 12:14 PM
wontacceptthis's Avatar
wontacceptthis
Glasspacks! RAAAAAAAAWRGH!!!!!!
Old Mar 20, 2011 | 03:46 PM
RamKing's Avatar
RamKing
any videos? saw a few on youtube
Old Mar 23, 2011 | 10:30 AM
RamKing's Avatar
RamKing
here are my headers
Old Mar 23, 2011 | 04:36 PM
royalD150's Avatar
royalD150
Thats how my ram exhaust is. The driver side pipe crosses above the drive shaft and runs with the passanger side all the way back. True dual turbo mufflers all the way. Its pretty quiet but i like that for now.
