New truck cuts off
Old Apr 8, 2011 | 06:15 AM
1989dodged100's Avatar
1989dodged100
thanks, truck hasnt cut off since i cleaned the fuel system has low oil pressure though. Anyone know what line is normal at idle
Old Apr 8, 2011 | 06:32 AM
SEAL's Avatar
SEAL
These idiot gauges are all different and, in my opinion, unreliable until you verify what they are telling you. I always recommend you pull the sending unit and temporarily replace it with a cheap gauge from the hardware store to find out what actual pressure you have and then you know what your gauge is telling you.
Old Apr 9, 2011 | 06:38 AM
1989dodged100
suprisingly none of the auto parts stores around here has a liquid gauge
Old Apr 9, 2011 | 07:10 AM
SEAL's Avatar
SEAL
You don't need a liquid gauge as the gauge will not actually see liquid oil. Pull the sending unit and take it to your local hardware store. Ask for a 0-100 PSI 2 inch pressure gauge for a water system and the proper size adapters to match the thread size on the sender. It shouldn't cost more than a couple of dollars. I like the 2 inch but a 1 1/2 to 2 1/2 inch will also work just fine. This will show you what it will look like.
http://www.grainger.com/Grainger/ASH...re-Gauge-5WG99
