Severe Brake Problem...Any Tips?
I was changing the brake pads on my 85 D100, and I didn't realize the calipers were in two parts. So I took off the brake line to get to the nut on the back side that holds that part of the caliper on. Anyway, now when I press the brake peddle it goes all the way to the floor. I've bled the front brakes at least 8 times, but so far nothing is working. Any tips? Also, is the bleed valve also the bolt that holds the brake line to the caliper?
I do not believe the bleeder valve holds anything on. I just hate brake problems! Do you have bendix calipers? I'm not really familiar with them. You should have somebody pump the brakes while you watch the lines and hoses for leaks. Provided there are no leaks and everything is assembled correctly, I would suspect a master cylinder or wheel cylinder.
i don't mind brakes. if you have leak in a brake line you should hear it shooting out brake fluid. i would open the bleeder screw the first time with a socket and then use a wrench. you turn that little notch thing counter clockwise to open it and clock wise to close it.
i have a 2x4 hold my brake pedal while i am opening the bleeder screws.
Must suck when you roll your quad, huh?
You don't really need anybody who knows what they are doing to help you bleed, if you go that route. Its faster than a 2x4, and doesn't require you to buy a vacuum bleeder. Just have them pump the pedal x10 times, hold while you crack the bleeder, the pedal will hit the floor, close the bleeder, and repeat the process until there is no more air coming out. Just ake sure you don't run out of fluid during the process.
