1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
You'd have to cut it once before or after the cat, run a rod of some sort through it a bunch, and splice it back together. You could either clamp a little piece of i.d. pipe over the existing o.d pipe, or make just one weld.
