truck will not start
Old Apr 13, 2011 | 06:23 PM
tooltime's Avatar
tooltime
Default truck will not start
A few days ago i started and moved the truck. Later i tried to start it and nothing no noise etc. Lights and the key buzzer does not work.I put a new battery in a few years ago aswell as the battery terminals. A guy i work with said it is the volt regulator. Can it be that or something else. I tried to jump it and that did not work. Anything else? thanks
Old Apr 13, 2011 | 07:02 PM
SEAL's Avatar
SEAL
What is the voltage reading at the battery? Take the battery terminals off and clean them. A bad voltage regulator would show up as a dead battery when it is running and not when it is sitting.
Old Apr 13, 2011 | 07:44 PM
tooltime's Avatar
tooltime
The terminals are clean no acid. So what could be the problem? It started and ran fine and the nothing. Thanks
Old Apr 13, 2011 | 08:18 PM
crazzywolfie's Avatar
crazzywolfie
have you checked your fuses and for voltage at the fuses?
