front brake pads
hey all, a while back i put new calipers,pads on the front of my 93 d150.
the problem im having is they rattle around,cause i did not put the shims in the rear inboard pad against the piston. i never put these in before,and never had a problem before. it must be a casting of the caliper problem or something. i did bend the tangs over on the outboard pad,they are tight.
does anyone know where i can get those flat piston to pad shims? do they need to be siliconed to the pad?? thank you
