89 dodge 5.2 question. Need Help!
Old May 4, 2011 | 02:29 PM
kingofsweet's Avatar
kingofsweet
Default 89 dodge 5.2 question. Need Help!
I have 89 dodge ram 4x4 w150 5.2L 318. I have no acceleration I press the gas pedal to the floor and it dies but idles fine I just replaced the fuel filter and lines and the pump has good pressure. Where might I turn to next? I am no Machanic but have to fix it myself due to very low funds. Can someone help me please?
Old May 4, 2011 | 07:42 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the first generation Ram section,
FF
Old May 4, 2011 | 09:20 PM
SEAL's Avatar
SEAL
Look in the throttle body and check the injector spray patterns. There should be a fine cone of fuel at the base of both injectors that reaches the sides of the throat of the throttle body with no gaps or streams. You may need to use a flashlight to see the cones.
Old May 5, 2011 | 12:17 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site
Old May 8, 2011 | 02:35 PM
Stephen318347's Avatar
Stephen318347
Default 318 motor
Hi,I was wondering if anyone could tell me the difference between a 318 Half Ton motor and the 318 Dakota Motor.Is there a diff in HP what else??
I have a 1992 318 Half Ton Motor to install in my 94 Dakota
Old May 8, 2011 | 02:37 PM
Stephen318347
Default Cam
What cam can I install in my 92 Half Ton 318 ?
Thks
Old May 8, 2011 | 02:51 PM
SEAL's Avatar
SEAL
Stephen: You are new to the site but highjacking a thread is bad etiquette. You should start your own thread for each new problem. If your 92 is stock with a stock computer there is very little you can change including the cam and still have it run acceptably.
Old May 9, 2011 | 07:22 PM
1969CoronetR/T
vaffanculo
Stephen, start a new thread instead of running on another's post. Tone down the attitude,
FF
Old May 10, 2011 | 01:28 AM
SixGun's Avatar
SixGun
Hey what did you find out King of Sweet? Don't let all that drama distract you.
Seal, I apologize for that guy, you sure didn't deserve that swat. I've seen you help a lot of guys out on this site for the past year. Thanks for removing it FF. Very disrespectful!
