stupid lean to the right
Old May 12, 2011 | 07:22 PM
fast_five_oh's Avatar
fast_five_oh
Default stupid lean to the right
so my dodge has a nasty drivers side lean....i mean horrible...
i put those joke spring lifter things in the coil and it did help...
what causes it to lean thought?
86 dodge d100 1/2 ton 2wd 318 shortbox
Old May 12, 2011 | 07:42 PM
crazzywolfie's Avatar
crazzywolfie
maybe the spring on the drivers side is weaker than the one on the passenger side.
Old May 12, 2011 | 09:08 PM
SEAL's Avatar
SEAL
If an old truck develops a lean it is usually to the left. The left always carries more weight than the right. The fuel tank is on the left and the fact that there is always a driver but a passenger is optional. Over time the added load can work on the springs.
Old May 12, 2011 | 10:35 PM
fast_five_oh
that makes total sense....i guess i need to search for a spring or 2 lol
thanks guys
Old May 13, 2011 | 08:10 PM
aje1127's Avatar
aje1127
could not only be the springs,but also could be the cab mounts.
i had the lean bad on the driver side,changed out the springs,still there.
there is also a tsb about these older dodges,the dealer added a rubber spacer on the driver side to level it out.the spacer is no longer available but the dealer can tell you what other dealer will have it its like 68 bucks.
i added the spacer,and put in all new pst cab mount bushings,now its better than new.good luck hope this helps
Old May 14, 2011 | 02:04 PM
tooltime's Avatar
tooltime
If the springs are bad would they still be straight? My truck is low on the front and left side is worse. Thought someone heated the springs but they are straight and not all over the place. Does anyone know what the height is when they were new
Old May 14, 2011 | 02:16 PM
ShelbyGT550's Avatar
ShelbyGT550
I may be wrong but I thought leafsprings were not supposed to be flat unless they are overloaded or under a load?
Old May 14, 2011 | 04:46 PM
SEAL's Avatar
SEAL
I replaced my original springs with 6 leaf heavy duty ones to help with the extra weight of my snow plow and mine are flat all the way across the top leaf without the plow attached.
