cam choices
Old May 27, 2011 | 10:23 AM
fast_five_oh's Avatar
fast_five_oh
Default cam choices
so im doing a rebuild on my 86 dodge d100 soon
im wanting a cam in it...heres my 2 choices
http://www.summitracing.com/parts/SUM-K6901/
http://www.summitracing.com/parts/SUM-6900/
i plan on running headers,intake/4bbl carb as well on it
just want a good sounding idle, and some more power
will be stock springs etc as well
Old May 27, 2011 | 11:00 AM
crazzywolfie's Avatar
crazzywolfie
i don't know a lot about cams but i was told if you are just installing something like an RV cam you should be ok with the stock springs. it is funny that i was looking at that exact same cam. they also offer that cam in a package with lifters. if you replace the cam it would also be wise to replace the timing chain and gears.
Old May 27, 2011 | 11:07 AM
fast_five_oh
i read on anything over 500 lift u hafta replace spring...im just unsure..
it also has new timing chain/gears about 2000 miles ago
Old May 27, 2011 | 11:10 AM
SEAL's Avatar
SEAL
What are you planning to use the truck for? I would go for the 6900 for lower end torque, power, and gas mileage but that is because mine is a work truck. If you want a slight lope do the 6901. JMHO
Old May 27, 2011 | 11:33 AM
fast_five_oh
well i use the truck for work an some travel...mostly around town an stuff...so both cams will work with stock springs i assume?
Old May 27, 2011 | 11:38 AM
crazzywolfie
it looks like you could use either cam with stock springs. i agree with SEAL. i would probably get the 6900 cam. it is the exact one i was looking at getting for my 81 when i get that far. just make sure whichever route you go replace the lifters.
Old May 27, 2011 | 01:20 PM
SEAL's Avatar
SEAL
Stock springs are OK with either cam but I would check to see if their free length is still within specs if you are planning to reuse your old ones. This is especially important if you believe they are original equipment.
Old May 27, 2011 | 05:55 PM
fast_five_oh
also to save on thread making...
is sealed power bearings ok?...thats my only choice is this small town...
anything special in an old mopar engine i need to worry about(i came from foxbody mustangs)
and more then likley ill be putting new valve springs in
Old May 27, 2011 | 10:34 PM
mr.318's Avatar
mr.318
I've used both them cams before, Both or good cams lowrange, But nethier one really had a lope,
Old May 28, 2011 | 05:53 AM
SEAL's Avatar
SEAL
Sealed Power bearings are fine. I have used them for over 40 years in many engines with no problems.
