1983 Dodge Ram have a reset ?
Old Jun 30, 2011 | 06:07 PM
Jim Robbins's Avatar
Jim Robbins
Default 1983 Dodge Ram have a reset ?
My buddy had his 83 Ram in to have the fuel pump replaced and the speedometer repaired /replaced . When he got his truck back the fuel guage does not seem to be working.
Is there a way to reset the systems after work was done. Any and all advice would be great! Thanks Jim
Old Jun 30, 2011 | 07:14 PM
aje1127's Avatar
aje1127
check fuel gauge ground,if the gauge cluster was out maybe a ground was distrurbed?? just a thought. good luck
Old Jun 30, 2011 | 10:19 PM
wontacceptthis's Avatar
wontacceptthis
They probably disturbed the sending unit while they did the pump. I'd suggest asking them to fix it.
Old Jun 30, 2011 | 10:27 PM
aje1127's Avatar
aje1127
the fuel pump on a 1983 is on the engine,mech. its not in the tank like fi.
Old Jul 1, 2011 | 06:10 AM
SEAL's Avatar
SEAL
I would check the connections to the gauge itself, If they replaced the speedometer they may have disconnected the gauge wiring and didn't notice it. They should be responsible for this if it worked when it went in.
Old Jul 1, 2011 | 08:57 PM
lxman1's Avatar
lxman1
Site Moderator
Yep, sounds like the plug on the back of the instrument cluster isn't connected properly.
