Driver Door Needed - what years fit?
Old Jul 22, 2011 | 05:01 AM
Kdcarter's Avatar
Kdcarter
Default Driver Door Needed - what years fit?
Novice help, please. My son needs a driver's door for his 1984 Ram 150. It has 1 inch wide chrome molding, only. What years of trucks will match his door? Thanks!
Old Jul 22, 2011 | 09:46 PM
tooltime's Avatar
tooltime
Finding a door with the molding maybe hard. If not mistaken 1981-1993 will fit. I have a 86 and replaced with a 84 i think. When you put them on make sure you have time bc you will have to adjust them and have some help. Good luck
Old Jul 23, 2011 | 04:52 AM
Kdcarter's Avatar
Kdcarter
Thanks for the help! Even if you are out a bit on the upper end (I have no clue), that large of a range should be helpful.
Old Jul 24, 2011 | 04:14 PM
RamKing's Avatar
RamKing
the pins on eariler models are bigger then later ones, i think 85 and older are bigger and 86 and later are smaller, my 87 has doors off of a 85 and had to repalce the pins so they would close
