thermostat
Old Jul 25, 2011 | 01:51 PM
Dodgeman707's Avatar
Dodgeman707
Default thermostat
Right now I'm running a 205f and its running warmer then usual so if I switched to a 160f would that help run cooler
Old Jul 25, 2011 | 02:39 PM
charlie1935's Avatar
charlie1935
180 is the lowest I would go.
Some report getting check engine light or a code with the 160.
Old Jul 25, 2011 | 04:31 PM
Dodgeman707
But technically the thermo would open sooner meaning it would run cooler or not
Old Jul 25, 2011 | 04:53 PM
SEAL's Avatar
SEAL
All engines are designed to be run at a certain temp. If they do not reach a minimum temp they will not reach peak efficiency. If it is computer controlled it will set codes and may never come out of limp home mode.
Old Jul 25, 2011 | 06:58 PM
Power-Wagon's Avatar
Power-Wagon
I just read through your post and I guess the question I would like answered is how much warmer is the truck running and why are you concerned?
Old Jul 25, 2011 | 07:38 PM
Dodgeman707
Around 3/4 to the hot end maybe half way on highways
Old Jul 25, 2011 | 07:52 PM
crazzywolfie's Avatar
crazzywolfie
have you checked your rad fluid level?
Old Jul 26, 2011 | 08:08 AM
SEAL's Avatar
SEAL
Sounds like you don't actually know what temp the engine is running at due to the use of an idiot gauge which is what my truck has also. Idiot gauges are only good for a reference of what is normal for that gauge/sender combination in that particular engine. Running a colder thermostat may or may not lower the temp that the engine runs at depending on why the engine is running at the temp it does. The thermostat only controls the minimum temp if the thermostat is working properly. After the minimum temp is reached any running temp above the minimum and any overheating is controlled by a lot of other factors but not the thermostat if it is working properly.
Old Jul 26, 2011 | 08:22 AM
wontacceptthis's Avatar
wontacceptthis
Did you have any problems with the 205 before? How long did you run it? Whatever thermostat was in my truck slowly started sticking closed more and more over a period of two weeks. I now run a 190 which has done just fine, winter and summer.
Old Jul 26, 2011 | 11:52 AM
Dodgeman707
Its been **** about 2 months now. How can u get an actual degree reading if the gauge is just a ball park figure
