Starting problem with an 87 D100, please help!
Old Jan 17, 2018 | 11:35 PM
  #31
lossecannon's Avatar
lossecannon
they are factory and the truck turns over just fine it just won’t start after I shut down if I drive to the store maybe 10 miles and shut down and try to start it will turn over but that’s it 30 mins later it starts
Old Jan 17, 2018 | 11:50 PM
  #32
crazzywolfie's Avatar
crazzywolfie
your issue is not the terminals is if will still turn over. have you tried holding the throttle open when it doesn't want to start?
Old Jan 18, 2018 | 08:42 PM
  #33
lossecannon
yes I have
Old Jan 19, 2018 | 06:25 PM
  #34
Moparite's Avatar
Moparite
When it doesn't start check if you have spark out of the coil wire. If so then it's a fuel issue. Injector sticking open???
