could this cause a knock in my 318
Old Aug 16, 2011 | 09:12 PM
jeremy2717's Avatar
jeremy2717
Default could this cause a knock in my 318
so anyway a couple months ago my fuel pump went in my 87 d100 and i had some gas leak into the pan. i changed the pump but didnt think anything about the oil until about 200 300 or so miles later when i checked the oil and smelled gas. it had a slight tapping before pump went but now is slowly getting worse. i cant quite tell where the noise is comming from but it sounds like the rear of the oil pan. after talking to a few people about it i was told it could be my torque converter bolts comeing loose cause apparently thats an issue. also told it may also be a crack in the flex plate. but i know that gas in the oil pan can cause bearing damage. any ideas on what it could be or things to try before spending money. thanks jeremy
Old Aug 16, 2011 | 09:46 PM
crazzywolfie's Avatar
crazzywolfie
have you change the oil yet? if not that is what you may want to try. if it don't get better after an oil change then you may have a problem.
Old Aug 16, 2011 | 10:02 PM
jeremy2717's Avatar
jeremy2717
i did change the oil and put a qt of lucas in noise still there. is the converter or flexplate a good idea or do you think it a bottom end problem. it does still run good no power lose that i have noticed
Old Aug 16, 2011 | 10:14 PM
crazzywolfie
if there was gas in the oil and an oil change did not help then you may have a bottom end problem. it is really hard to say.
Old Aug 16, 2011 | 10:47 PM
jeremy2717's Avatar
jeremy2717
would it be worth it to rebuild bottom end or just look for a new motor the parts i can think of needing are only gonna run me about 350 or so not about 550 to do a bb swap witch i was thinking bout just not in the budget now i can get anytime tho i now where 2 r sitting.
heres the list of parts i can think of that i would need or just much easier to replace with motor out let me know if you can think of anything else i might need would be great
crank kit w/ main and rod bearings
timing chain set (double roller)
full engine gasket set
freeze plug kit
oil pump and pickup
Old Aug 17, 2011 | 05:58 AM
SEAL's Avatar
SEAL
I like to have as much information as possible. I would do a compression check to find out what shape the top end of the engine is in before making a decision on what to do.
Old Aug 17, 2011 | 12:18 PM
jeremy2717's Avatar
jeremy2717
from what i can tell the compression is good it only has 110k on it. i had to retime it not long after i got it and using a ratchet on the crank pully to turn the engine over to tdc on the number 1 cylinder i had to put some muscle into it to turn so compression feels good but thats the best i can do without an actual compression tester. i have felt motors with low compression so i do have a good idea how they should feel. so with the info provided what do you think bout my part list. anything i should add or am i good to go with what i listed providing it is only the bottom end. (witch i really think is the only problem) thanks jeremy
Old Aug 17, 2011 | 12:59 PM
crazzywolfie
i agree with SEAL. a compression test could reveal if you have some problem.
Old Aug 17, 2011 | 02:11 PM
jeremy2717's Avatar
jeremy2717
ill look into getting one im driving it to work tonight to look at a few other things if i have time anyway. ill ask one of the mechanics if he has a tester before he leaves im sure i can get one. whats a good range to be in so i no what im looking for. thanks again jeremy
aslo any thoughts on the converter or flexpate
Old Aug 17, 2011 | 02:26 PM
crazzywolfie
100psi minimun; no more than 25psi variation between cylinders.
