70's bumper/hood on 86
Old Sep 1, 2011 | 04:24 PM
fast_five_oh's Avatar
fast_five_oh
if u scroll up look at the pics...the hood that isnt on my truck is a birdbath....why do they call it that? well look at it...it holds water lol..hince the name
i love them since i first learned about them a month ago...an i HAD to have one...
and heres pics on my latch modifcation..cut a hole..drilled welds...mocked up...welded...then tested...
this is the hardest part people dunno how to do..again this is an 86 truck, with a 78 hood...these pics should explain most things
and heres the finished(almost) product...also with the 78 thinner bumper
Old Sep 1, 2011 | 04:47 PM
}{ead$hot Zod's Avatar
}{ead$hot Zod
WOW.... if I told you I was looking to see if anybody had done this modification "TODAY" and went to join the forum only to find out I was already a member and haven't posted in like four years would you believe me? Great job!!!
Old Sep 1, 2011 | 06:46 PM
aje1127's Avatar
aje1127
i believe he is refering to the dips/indentations on the hood that hold water when it rains. they fill up with water and every time you open your hood the water dumps out on your dist. cap and wires and collects moisture,and makes it run like crap. if this happens the fix is use PERMATEX DIE-ELECTRIC tune up grease on everything ie.. cap, rotor, wire connections, and even a lite coat inside the cap on the contacts.
thank you
Old Sep 1, 2011 | 07:38 PM
89ram150's Avatar
89ram150
Not to get sidetracked but is your truck an LE? Looks like you have all the same trims and mouldings mine did til I stripped it.
Old Sep 1, 2011 | 07:52 PM
serge627's Avatar
serge627
Wow!!! That turned out really nice, great job!
On a side note, what wheel and tire size are you running?
Old Sep 2, 2011 | 11:26 AM
fast_five_oh
thanks, wheels are 15x8 fronts, 15x10s rear, tires are 235/75's
soon to be 15x10 wheels in front ant 275/70 rears and 265/70s front..or maybe smaller sidewall...dunno yet lol
Old Feb 4, 2012 | 01:05 AM
wontacceptthis's Avatar
wontacceptthis
Not to drag up a dead thread or anything, but this gives some good background. I have a chance to get a birdbath hood for dirt cheap tomorrow. So do you HAVE to use the old cowl, or is is just a little "off" if you go with the newer one?
