fuel problem 1986 360 4BBL
1989 dodge Dokota truck want idol or run right real rough
Need some direction i think it is a fuel problem.i unhook gas line from throdalbody turn key on fuel pump put out one little squirt of gas then the relay kick the fuel pump off. I thought a electric fuel pump would keep on pumping as long as the key is on and not building up pressure but for some reason the pump relay kick the pump off.Once it kick off we turn the motor over and gas started comeing out of the gas line but it was real weak. So why did we half to crank the motor over to get gas to come out that's not right. when the key is turn on the fuel pump should kick on and build up so much pressure is that right? I need to now if it is the fuel pump or relay or crank senser or something else can yall help me with some guidance please thanks.
