1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
a vacuum leak should not cause your truck to quit running.
You wouldn't think so but I've seen it. On an '84 Camaro I helped a friend with, when he turned the defrost on it would drop dead, like turning the key off. Worse case it'd let out a massive backfire on its way out. Turned out almost every vacuum line behind the dash to the hvac controls was either broken or just not there at all.
