fuel injectors ??
Old Oct 2, 2011 | 01:53 PM
aje1127's Avatar
aje1127
Default fuel injectors ??
does anyone know the best way to clean injectors on my 93 318 magnum?? im thinking to pull all of them out and soak them in a sonic cleaner. will this work?? how much work and cost to rebuild them?? thank you
Old Oct 5, 2011 | 06:20 PM
moe7404's Avatar
moe7404
marvel mystery oil. use 4 oz in 10 gal of gas, in the tank. check out "Bob is the oil Guy". the mmo will take a while to work. but its easy to use. been using it for 3 decades.
Old Oct 7, 2011 | 08:46 PM
pickerbush18's Avatar
pickerbush18
Not that hard to take out but kinda hard to put back in. I would use an injector cleaner in the gas if the plugs are not showing a problem. I had 2 plugs foul constantly so I finally pulled the injectors and the 2 were plugged at the top. Hooked to my battery to open and shot Wd-40 into them and they opened right up after a few shots. Truck works great now.
Old Oct 8, 2011 | 08:22 AM
SEAL's Avatar
SEAL
Just a warning. If you are using a battery to open the injectors you can burn out the injectors if the voltage is applied for too long.
Old Oct 9, 2011 | 11:43 PM
SixGun's Avatar
SixGun
Aje, I used Fuel Injection Specialties on 11051 Wye Rd. just off Perrin Beital in NE San Antonio. Charged me $45 each injector. ph: 210-654-0774.http://www.fuelinjection.com/ I thought it was pretty to remove them following the procedure in the manual.
Old Oct 10, 2011 | 05:35 AM
aje1127's Avatar
aje1127
thanks sixgun,for the leed on the EFI shop. i have no loss of power at all,just sometimes hard starting when sitting over night. fuel pump/sending unit are only about a year old,new filter,and just changed out the pressure regulator.
oh forgot to mention a slight rough idle now and then.
i pulled the spark plugs and they were kind of rich,from excess fuel drip at the injectors. for now i will change the plugs and run something good through the gas tank maybe i can get it to clear itself. thank you
Old Oct 10, 2011 | 07:29 AM
SEAL's Avatar
SEAL
I highly recommend a full can of SeaFoam for a full tank of gas for injector cleaning. If your driving is erratic I suggest you use a time when you are using the tank of gas over the longest period of time. This allows the injectors to be exposed to the cleaner longer than say on a trip where you use the full tank in a couple of hours.
Old Oct 27, 2011 | 06:43 PM
aje1127's Avatar
aje1127
i had to change my computer(ecu/pcm) cause of another issue.
it starts up and runs 120 % now,so my injection problem was also due to the bad computer.
also the computer showed no trouble codes either.
