Exhaust Advice Needed
Old Oct 4, 2011 | 08:08 PM
1992antihero's Avatar
1992antihero
Originally Posted by aje1127
well if it wasnt that loud without the muffler when you started it,your cat. may be partially clogged. most people pull off the cat and if you need it on there they put a high flow cat on. this will also ma ke any muffler you decide to use sound better,anfd flow better. i have a FLOWMASTER SUPER 44 on mine,with a high flow mini cat,dumped before the rear axle.
your v6 will only sound alright at lower rpms. good luck
How do I check if my cat is partially clogged? And I don't think high flow cats will pass emissions unfortunately.
Old Oct 4, 2011 | 08:12 PM
1992antihero
since his truck is a 92 is should have a magnum engine. before he goes replacing the cat or muffler he may want to fix the plenum or it would just be a big waste of money doing the exhaust. the more the plenum leaks the more oil is burnt and the faster the cat clogs.
https://dodgeforum.com/forum/2nd-gen...um-thread.html
Ya its the V6 Magnum. And I looked at that plenum post before and my truck shows none of those symptoms. So I think my plenum is fine.
Old Oct 4, 2011 | 08:24 PM
crazzywolfie's Avatar
crazzywolfie
i doubt the plenum is fine. most people think there truck is running great up until there cat clog and they loose all power and then they wonder what the heck happened? my neighbors cat clogged about 1 week after i was talking with him about the plenum gasket.
the only problem i could see with using a cat from a different vehicle is it may not have the air injection port on it.
Old Oct 4, 2011 | 11:15 PM
wontacceptthis's Avatar
wontacceptthis
As for the muffler, i meant the regular cherry bomb. The glasspack. The granddaddy of snap, crackle, pop. I've never been pulled over for noise, and i swear my truck is quieter than the average guy with flowmasters still.
Old Oct 5, 2011 | 03:57 AM
1992antihero
Well so far my truck has zero loss in power. Trust me I tested it good lol. I put the truck in second gear got the revs up, popped the clutch and got a pretty badass 10ft burn out.
What is the air injection port?
Old Oct 5, 2011 | 04:03 AM
1992antihero
Ya looked into the glasspack, but you gotta remember my truck is a V6. So it may not sound good with that. Thats why I'm most likely gonna purchase the CherryBomb Pro. Which is just a step below the glasspack. I'm going back to the autoparts store this Saturday to pick up a new muffler. If any body is interested I can post some pics of it when I'm finnished. Cause I'm redoing most of the exhaust. Including relocating it. I can also do a video to. Let me know.
Thanks
Old Oct 5, 2011 | 04:06 AM
1992antihero
If anybody would like me to, I can take a video of the truck now without the muffler to show you how quiet it is. Maybe this will help.
Old Oct 5, 2011 | 11:13 PM
wontacceptthis
Oh yeah. Forgot we were talking about a v6.
Old Oct 6, 2011 | 08:19 AM
SEAL's Avatar
SEAL
An injection port is a pipe in the side of the converter that feeds oxygen/air into the converter to help it complete its burning of the fuel and NOX compounds. It is fed by the air pump.
