1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Well, I marked the tire and yoke then turned the tire one revolution slowly, the yoke only turned 1.75 times. I did it twice with the same results, seems a little weird doesn't it?
You have the 3.55. Turn one wheel on an open differential turn the wheel two times or one time and mutiply by 2.
My next question is about the strength of the rearend. I am building this truck to be somewhat of a hotrod and with most likely be swapping out the 318 for a built 408 small block or a pretty hot 440. For now the 318 will be rebuilt to get the most performance out of it that I can. How much power is the stock 9-1/4" capable of holding?
