flickering/pulsating lights??
Old Dec 12, 2011 | 09:50 PM
  #31
fast_five_oh's Avatar
fast_five_oh
im having the same deal with my 86....im carbed though...i also just added a aftermarket cam which i dont think causes it..but id place a bet its an alternator grounding issue or regulator maybe
Old Dec 12, 2011 | 10:01 PM
  #32
crazzywolfie's Avatar
crazzywolfie
checking the ground connection is always important. in the summer when it was warm and dry the amp gauge would move a lot when i turned things on like turn signals. when it was wet out amp gauge would hardly move at all under the same conditions.
if the one post on the alternator is not getting 12 volts when the truck is running i would almost be interested to see what would happen to it if 12v was applied.
Old Dec 17, 2011 | 02:47 PM
  #33
aje1127's Avatar
aje1127
well i just pulled off the 12v ignition feed to the alt. feild term. then hooked up to battery 12v,which should eliminate the ignition switch and the asd relay.still puts out 15.3volts. what to do now. i wish i could figure this repair out the wright way. what to do next??? this is a PITA. THANK YOU
Old Dec 18, 2011 | 11:41 AM
  #34
aje1127's Avatar
aje1127
i guess i covered all the bases to repair this. i may have 1 more item to check,i need to find the main ground for the computer. if that is ok which it should be,then there is no problem and that is just the way this is. thank you
Old Dec 19, 2011 | 08:04 PM
  #35
fast_five_oh
well i think i solved mine..seemed to be a loose battery cable..possible bad battery..ill see
how it goes the next few days
Old Dec 19, 2011 | 10:05 PM
  #36
fast_five_oh
well my battery seems to have died tonight lol...more testing tommorow
Old Dec 27, 2011 | 09:18 PM
  #37
fast_five_oh
so i did more trouble shootin..i bought an optima battery after my crappy valucraft went bad..
it still pulsated, escpecially when the headlights was on, so intalled better ground cable,and made sure it had a good body and motor ground...still did it..
so i got a 12ga peice of wire, wirebrushed a small bolt to bare metal on the alternator, made a good ground on the rad support...that has seem to fixed my problem so far..i dont do alot of night driving so results may change
Old Apr 15, 2023 | 10:01 PM
  #38
Darren Bell's Avatar
Darren Bell
i know this was 12 years ago 🤣but I'm having the same issue and just wondering if you ever solved your issue. ?
Old Apr 16, 2023 | 05:51 AM
  #39
Moparite's Avatar
Moparite
Don't expect an answer, He hasn't been here since: Last Activity: 07-12-2012 03:42 AM
