Steel?
Old Nov 15, 2011 | 01:12 PM
JGC403's Avatar
JGC403
Default Steel?
Anyone know what type of steel is the frame and suspension components made from?
Old Nov 17, 2011 | 07:14 PM
wontacceptthis's Avatar
wontacceptthis
The rusty kind
Old Nov 19, 2011 | 12:23 AM
moe7404's Avatar
moe7404
only know to NOT weld them. a little grinding is ok or drilling of it doesnt get hot. but dont take to much metal off. iam sure its a alloy, but dont which one.
Old Nov 19, 2011 | 06:48 AM
SEAL's Avatar
SEAL
Why do you believe that you can't weld on a frame? I have ground, welded, and drilled my frame without problem. "ALL" steel is an alloy. Basic steel is an alloy of carbon and iron. Then they add other elements to get the exotic steels.
Old Nov 19, 2011 | 09:05 AM
Wombat Ranger's Avatar
Wombat Ranger
Whatever steel it is it is very basic, nothing special. Welding to the frame is perfectly safe, as long as you know what you are doing with a welder.
Old Nov 19, 2011 | 10:09 AM
JGC403's Avatar
JGC403
Ok. I wanted to box the frame on mine. Didn't know what kind of steel to use.
Old Nov 19, 2011 | 11:03 AM
Wombat Ranger
Shoot any 'ol plate steel will do just fine. I would use 3/16" to match the rest of the frame, making it easiest to weld.
