1985 Ram electrical issues
Old Nov 19, 2011 | 01:04 PM
vinnie1069's Avatar
vinnie1069
Default 1985 Ram electrical issues
Hey guys, so I am having some issues in my 85 318 2wd Ram. I seem to have a shortage of electrical power. For example, the battery starts the truck just fine, but once I am moving, my stereo will cut in and out whenever I hit the brakes. Also, if the headlights are on, they are really dim, and amplify the brake/stereo not working. I have replaced the battery, alternator, voltage regulator, and ignition switch and am still having this proble. I am at a complete loss for what may be happening. No matter what I try, I cant track down the gremlin. Anyone else have issues like this, and what did you do to resolve the issue?
Thanks a lot,
David
Old Nov 19, 2011 | 05:11 PM
crazzywolfie's Avatar
crazzywolfie
does the amp gauge move much? i would probably try running a jumper wire from the large lug on the to the battery terminal. this should bypass the amp gauge which i think could be limiting the voltage getting to all the electrical things. you could also put your headlights on relays.
Old Nov 19, 2011 | 05:20 PM
vinnie1069's Avatar
vinnie1069
Come to think of it, the ammeter rarely, if ever actually moves at all... What do I do to bypass this? A jumper cable from the large lug on what?
Old Nov 19, 2011 | 05:25 PM
crazzywolfie
on the alternator.
Old Nov 19, 2011 | 05:27 PM
vinnie1069's Avatar
vinnie1069
Thanks. I'll give it a try when I get home...
