Brake Problems, tried everything, now what?
Old Nov 17, 2011 | 05:07 PM
Dodgegirl88's Avatar
Dodgegirl88
Default Brake Problems, tried everything, now what?
I don't know if I'm in the right place or not. But I have a 95 dodge 1500 4x4 5.9 engine. Been having weird brake problems. We've changed everything. When I back up I have no brakes. Pedal goes to the floor. But most the time its only when I turn and back up. If I back straight up I have a decent brake. Now when I am driving forward I will sometimes have good brake but then out of no where I'll have nothing.
If anyone has any ideas or suggestions please let me know. We have spent a ton of money changing things and nothing has fixed it. Thanks
Old Nov 17, 2011 | 06:19 PM
crazzywolfie's Avatar
crazzywolfie
you are correct about not being in the right section but we might be able to help anyways since brake are pretty much all the same.
are you sure you got all the air out of the lines? did you bleed them in correct order RR, RL, FR, FL? did you adjust to rear brakes out far enough to be snug?
Old Nov 17, 2011 | 07:43 PM
Dodgegirl88
We sure did. We checked the bearings by seeing if the wheel will shake and one did turned out the hub came lose and even lost a bolt. We tightened it up and my brakes were a lot better.
Thanks for your reply and sorry I posted in the wrong spot. I'm mobile and not able to see all the options. Thanks again!
