Removal of Emmissions Control Devices Question for Older Trucks
Old Nov 20, 2011 | 02:52 PM
pumbu's Avatar
pumbu
Default Removal of Emmissions Control Devices Question for Older Trucks
I have a 1982 Dodge D350. I live in Virginia and am not required to have an emissions inspection for a vehicle over 25 years old.
I replaced my Carter TQ carb with a Edelbrock 1406 which is a non-emissions carburetor.
Which of my emissions related vacuum hoses do I need to reconnect to the carb?
-- Do I need the EGR hooked up?
-- I do have the PCV hooked up.
-- Are there other components that I can now remove, such as the Air Injection System?
-- Will not connecting the aspirator air system back to air cleaner become a problem?
-- Which hoses that were once connected to the carburetor and air cleaner can I plug up and not have a negative impact on perormance or cause any damage to the vehicle?
Thanks!
Old Nov 21, 2011 | 11:23 AM
Wombat Ranger's Avatar
Wombat Ranger
As far as i know egr can just be plugged. I believe that your motor will not run near as strong with the aspirator disconnected. LOTS of others have taken emmisions off their motor, I am no expert but i think the best way is to just install a non emmisions intake manifold, then hook up the few vacuum hoses that are still there. Good luck, maybe someone smarter then me will speak up
Old Nov 21, 2011 | 12:50 PM
pumbu's Avatar
pumbu
Thanks for the help and insight. Very useful. I will continue my research before I do anything irrevocable.
Old Nov 21, 2011 | 02:42 PM
SEAL's Avatar
SEAL
The problem with removing the EGR is the possibility of ping or knocking do to a rise in combustion chamber temps. You can make a cover plate for the manifold to take the place of the EGR valve to see if you get any ping or knocking. This is not radical and can be reversed easily by reinstalling the EGR valve.
