rain guard for w150
hey guys, i got a 1993 dodge w150 and my rain guard thats on my roof above my wind shield is all rotted and i am wondering if u guys had ran into this problem and i was wondering if their is a piece that is made that goes over it or if not how would i repair something like this
thanks,
cam
thanks,
cam
Im not sure what you mean by rain guard. Im guessing you are talking about the mini gutter that runs above the windshield and doors?
I imagine this is somewhat common since water sometimes pools in it, prolly will just have to bondo it up or something. Unless you can weld
It is usually the roof itself that attaches to the gutter that rusts thru. The repair is totally dictated by how bad it is but there are no replacement parts for this. This is basic body work.
neonimus00" You are in the wrong forum. Try here for help.
https://dodgeforum.com/forum/dodge-neon-6/
Cam, I have the same problem and mine is real extensive. The rail and sheet metal above the windshield are gone. I figure the best bet is to cut a front piece off another truck and weld it on. At the boneyard over here there are a lot of trucks with this same rot. I did a search a long time back on the net and found someone that removed the drip rail from his Ford truck. Doesn't look too hard if that's all the rot you have. Just have to drill out some spot welds. Opinions vary as to whether it will leak through the door seals with this piece removed. Looks good though.
Trending Topics
I have some minor rust on my roof gutter and plan on brushing out the loose pieces with a Dremel and putting some POR15 Patch in the groove. It is like tooth paste and will harden up very hard. I am not sure if this would work if the gutter is totally deteriorated.
http://www.por15.com/PORPATCH/productinfo/PPB/
