What model truck is this? VIN included.
Old Jan 17, 2012 | 03:38 AM
hamsucre's Avatar
hamsucre
New Member
Default What model truck is this? VIN included.
I am attempting to help my mom out with her truck. Its a 1987 Dodge "LE 150". VIN number is 1B7FD14T2HS417337.
I have attempted to search google,and various forums without success. My goal is to discover what steering columns will bolt into my mom's truck. I am also unsure as to what exact model the truck is. I would appreciate any help.
Thanks
Old Jan 17, 2012 | 06:32 AM
SEAL's Avatar
SEAL
Try this.
https://dodgeforum.com/forum/1st-gen...rmation-2.html
Old Jan 17, 2012 | 07:11 AM
sls001's Avatar
sls001
You entered the VIN Number: 1B7FD14T2HS417337
1 Country of Origin USA
B Make Dodge
7 Type of Vehicle Truck
F GVWR 4001-5000#
D Truck Line 2wd
1 Series 150
4 Body Conventional Cab
T Engine 318/5.2 2BBL or 360/5.9 4BBL (Federal) for 82
2 VIN Verification
H Model Year 87
S Assembly Plant Warren Main Plant or Dodge City for 88 & later
417337 Sequential Serial Number
Old Jan 17, 2012 | 10:59 PM
wontacceptthis's Avatar
wontacceptthis
In short, its a d150. Steering columns from about 80 to the advent of airbags (91? 92?) for a d150, d250, d350 should be the same, I would guess. I'm not sure if the 4x4 w150-w250-w350 used the same part. Make sure you get the right auto or manual column.
Old Jan 17, 2012 | 11:16 PM
crazzywolfie's Avatar
crazzywolfie
i think the big thing would be where is the dimmer switch located? if it is on the floor you will most likely have to locate a steering column that is 87 or older and if the dimmer switch is on the steering column then you will most like likely need a 87-93. i think the steering column up to 93 would also work but the connector for turn signals light and stuff is different so you would most likely have to do some splicing. i am almost certain the ignition connector is the same so that should be plug and play.
Old Jan 18, 2012 | 06:08 AM
SEAL's Avatar
SEAL
You need to also be sure if the truck has cruise control or not and if it is tilt or solid column.
Old Jan 21, 2012 | 04:56 PM
xjarhead69's Avatar
xjarhead69
What is wrong with the column thats in there that it needs to be replaced?
Dave
