injector
Old Feb 12, 2012 | 09:32 AM
Dodgeman707's Avatar
Dodgeman707
Default injector
hey my 91 w150 has a 90 360 with indy x heads, comp cam and 10.5 cr. i still have the stock tbi on with an edelbrock manifold. do they make performance injectors for our tbi's or are stock the only options. wanted to carb it but ran out of time and money lol. any suggestions? thanks
Old Feb 12, 2012 | 11:25 AM
sls001's Avatar
sls001
No...only stock injectors the early dodge TBI.
How does the it run in general? I ask since there is nothing that can be done for custom tuning with the TBI systems...
Also, which cam are you using?
Old Feb 12, 2012 | 12:07 PM
SEAL's Avatar
SEAL
sls001: I know there aren't any listed injector replacements at the parts stores but have you ever checked with an injector shop to see if there are higher flowing injectors that might fit our application? They have all of the specifications.
Old Feb 12, 2012 | 12:14 PM
Dodgeman707
honestly i dont know how it runs cause im in afghanistan right now and my dad is rebuilding the engine. hes putting it all together and hes worried that its going to run to lean with the stock tbi setup. it has a comp extreme cam
Old Feb 12, 2012 | 12:23 PM
SEAL's Avatar
SEAL
I would say he is right to worry about that. It may run but the injectors will be a big limiting factor on performance. Most people go back to carb and sh.tcan the computer for electronic ignition.
Old Feb 12, 2012 | 12:40 PM
Dodgeman707
i think he didnt go carb because the tranny is controlled by the computer or something. is there a way to go carb with using the a518 tranny
Old Feb 12, 2012 | 01:19 PM
SEAL's Avatar
SEAL
Yes there is a kit.
http://www.transmissioncenter.net/SwapInformation.htm
Old Feb 12, 2012 | 01:21 PM
sls001's Avatar
sls001
Seal: even if a shop could make custom injectors the factory computer will not have the ability to compensate and supply the necessary PW.
The trans OD only is controlled by the computer (as is the voltage regulator, ac, and cruise) but it can be easily switched to a vacuum\electric set up or even a manual switch.
The factory computer has nearly no ability to compensate for the modifications you have done...don't be discouraged though there are ways around it either with a carb or after-market fuel injection.
The biggest concern should be the static and dynamic compression ratio...and how bad the detonation is going to be...that is why I asked about the cam specs.
Do you have the parts list of what your father used in he engine?
Old Feb 12, 2012 | 01:39 PM
Dodgeman707
not on me right now but ill try to find out
