Vacuum Advance?
Old Feb 24, 2012 | 06:37 AM
  #21
DevilDogge's Avatar
DevilDogge
did you have the vacuum advance hooked up when setting the timing? if so that could be part of the problem. you are suppose to disconnect it when setting the timing.
Yes I did have it hooked up. I wondered that, but if it's not hooked up when you set the timing, then hook it up when you drive it, won't the timing be off?
Old Feb 24, 2012 | 06:47 PM
  #22
crazzywolfie's Avatar
crazzywolfie
i think that is the point. usually your vacuum decreases as your throttle opens so the timing would jump to where it was set without the vacuum line hooked up which i think would advance the timing.
