Power Steering Gearbox
Old Feb 23, 2012 | 02:40 AM
Stronghold07's Avatar
Stronghold07
Default Power Steering Gearbox
Hey guys, got a new 87 D-150 recently, steering was sloppy, you know the story. So I rebuilt the coupler, this took about half the play out. In the process of beating prying and heating the coupler to get it off the gearbox I seem to have broke the seal on the gearbox and now it loves to drink power steering fluid. My question is what brands of gearboxes have you guys used and recommend? I could just rebuild it, but I figure if I put a new or re-manned one on that it would eliminate the rest of the play. I'm on a budget.
Old Feb 23, 2012 | 07:21 AM
wontacceptthis's Avatar
wontacceptthis
Mine started leaking a while back, and quickly too. I used some of this http://www.lucasoil.com/products/dis...tid=9&loc=show and it worked. Granted, mine was an old worn seal, not a broken one. The good thing is that its only a $7 gamble. It has worked for me so far. I have no experience with replacing the box, thankfully.
Old Feb 23, 2012 | 04:14 PM
Stronghold07
yeah i thought about using some stop leak but i figured some of my steering play is coming from that so i might as well replace it
Old Feb 23, 2012 | 04:27 PM
SEAL's Avatar
SEAL
If heating the coupler caused the seal to leak, I would doubt any kind of stop leak is going to work. Last one I installed was a reman from Advance Auto. First one leaked from day one but the second (warranty) replacement is still working fine after about 8 years. Do yourself a favor and do the hoses at the same time. Be careful with the hoses at the back of the pump.
Old Feb 24, 2012 | 07:36 AM
Stronghold07
thanks SEAL, I just ordered it online, they have a 15% off and free shipping to my door. should be in by next week, ill let you all know how it goes
Old Mar 2, 2012 | 08:22 AM
Stronghold07
got the gearbox changed, after i went and bought a pitman arm puller, broke it, returned it for another and got it off then. kept the stock hoses, they seemed to be in good shape, put new o-rings on. took it for a test drive and man is it tight! it feels like factory again. now just need to do an alignment and i can check "steering" of my to do list
