5.9L or 440 cu. in.
Old Mar 7, 2012 | 02:58 PM
SEAL's Avatar
SEAL
Both will fit in your truck.
Old Mar 7, 2012 | 10:48 PM
Wombat Ranger's Avatar
Wombat Ranger
no the blocks are not the same size. the bell housing on a 440 or Big block is different than the bell housing on on a 5.9 or small block. a 440 will fit if you get a big block transmission and it has the right oil pan and pickup. there are websites that sell the parts you would need to do the conversion.
http://bouchillonperformance.com/BPEtruckKit.asp
Dangit Wolfie had what I was gonna show you already my bad.
Old Mar 7, 2012 | 10:49 PM
RSDodgelover's Avatar
RSDodgelover
As has already been said either will fit in your truck with the right trans, oil pan and exhaust maniflds or headers. These parts are usually at a premium and often not "available" because the people you are talking to about them don't really know what they are talking about. There is an easy way to know whether it is a big or small block is Big Block = front distributor, Small lock = rear distributor. I had two trucks with big blocks and loved them both. As you said originally "there is no substitute for cubic inches". Good Luck with whatever you decide to do.
Old Mar 8, 2012 | 04:59 PM
Magnum4406's Avatar
Magnum4406
You can find parts here to do the swap also http://www.engine-swaps.com/Pages/Pr...7BRBtruck.html
Old Mar 9, 2012 | 05:11 PM
jvanhoe's Avatar
jvanhoe
Thanks Magnum 4406, that site is great. It will certainly help w/ parts & making a decision of what I want to do.
Old Mar 10, 2012 | 11:58 PM
wontacceptthis's Avatar
wontacceptthis
The 360 is an LA series engine, while the 440 is an RB. They are not the same design. Yes, it would fit. But as far as your criteria of basically dropping it in like its another smallblock, no. You could always do a 408 stroker.
Old Dec 13, 2013 | 01:32 AM
shovlhead83's Avatar
shovlhead83
New Member
They sell motor mounts too. At least for trucks up to 93. It's a pretty easy swap.
