A problem I didnt realize was a problem, tranny?
Ok so I didnt ever really ask anybody until today about this so now it sounds like a might have a problem. Possibly with my transmission. One reason I wanted new gears was because I thought it would help rolling when on a hill. I figured the fact that acceleration was a little slower with big tires would be the same problem with the rolling but was talking to a friend on mine who is a mechanic said that it sounded like maybe a transmission problem but probably wasnt serious.
An example would be like in a stick shift when sitting on a hill (waiting for a light or something) during the time you take your foot off the brake and start to engage the clutch and give it gas you tend to roll backwards some, well my truck does that and it isnt an automatic. I notice this especially when I back out of my steep driveway, I have to give it alot of gas and if i stop on the hill i tend to roll a good bit then give it excessive gas which Ive skidded my tires before trying not to roll down into my garage.
Does anyone know what exactly this could be? Is it worn gears or soemthing?
You mean your truck is an automatic, right? Its fine. Your torque converter has to allow for some slippage so that you can idle in drive at a stop without stalling. Completely normal. I know that all the overdrive auto dodge transmissions I have experience with have a very "mushy" feeling torque converter. My trucks torque converter is pretty low stall and doesn't like to slip any more than it has to. Most hills it will climb at idle, but if its really steep it will stay still or drift back a very little. Always use the brake to keep you stationary, because if you rely on the pull of the transmission to fight gravity, you are just adding extra wear to all the clutches.
If your truck does it more now than when it was new, it could indicate wear. Big tires and a low numerical axle ratio means that your transmission is doing over time. I wouldn't really worry about it. An automatic transmission is essentially a wear item, and you might be swapping axles soon and giving it a break anyway.
And for axles, if I can find another deal then yeah. But so far the one I posted was the best deal. I cant afford 4 grand each on an axle.
