Will 6" lift on 35's fit in 7ft garage?
Old Apr 11, 2012 | 10:31 PM
Moparfever4ever's Avatar
Moparfever4ever
Default Will 6" lift on 35's fit in 7ft garage?
Hey guys, I wana lift my 86 gasser but I want it to still fit in the garage. I'd like a 6" lift on 35's but I been told that wont clear. Which doesnt make sense considering w/ new springs and 50% 31's I have 9 1/2" from the cab center to my 7' garage frame. Thats to the frame not door, the door hangs 1.5" but can prop past the frame.
Anyway, if my math is right, 35's would raise the truck 2" inches for a total of 8" with 1 1/2" to spare. Now could you guys tell me if you clear, and if not buy how much, also measure your garage frame? Even you guys with 4" lift on 33's can reply with clearance measurements if you would.
Thanks
Old Apr 11, 2012 | 10:45 PM
crazzywolfie's Avatar
crazzywolfie
if it don't fit you could let a bit of air out of the tires. my dad use to do that to get his van into one body shop he worked at. it happened to sit higher than the average van.
Old Apr 11, 2012 | 11:14 PM
dlyter09's Avatar
dlyter09
My 92 only has like a 4 inch lift i beleive and i could easily fit 35's
Old Apr 12, 2012 | 11:07 AM
Wombat Ranger's Avatar
Wombat Ranger
+1 on that. Many run 35's with only 4" of lift.
And if you trust your math, then who cares what the other guy says? Probably just flapping his lip.
Old Apr 12, 2012 | 08:49 PM
Comrade General's Avatar
Comrade General
I have a 4in and 35'' tires. I barly fit in my garage at home. My antennas hits (not a big deal) and my clearance lights are roughly 1 1/2'' to 2'' from hitting the bottom of the garage door. My driveway however is on a steep hill and I think if I back it, Ill have slightly more clearance but Im glad I didnt get a 6'' for this very reason.
As for commercial parking garages, i dont know. I have not driven in one yet
Old Apr 13, 2012 | 01:06 AM
Moparfever4ever
No commercial just 7ft. How tall exactly is your frame and are you measuring to the door? Cuz doors can be propped up another 1.5". What are service lights btw? Could you do me a favor and precisely measure to the center of the cab not guess? Cuz "roughly" 1.5"-2" from the lights to door could be 2.5"-4" from cab to frame. I'm surprised you dont rub w/ 35's, how hard do you wheel? What kind of lift/tires and wheel width/backspace do you have? I was told at RCC that only mall crawlers can run 35's. Once you start flexing and turning you'll rub bad.
Thanks
Old Apr 13, 2012 | 01:35 AM
Moparfever4ever
I trust my math, but not all lifts/tires are equal. The guys at RCC told me I need 6" lift to run 35's and it wont fit in a 7ft door once I do. I find it hard to believe spring manufacturers would be 1-2" over advertised lift (if anything I'd think they'd come up slightly short) and most 35's aren't true 35 inches (34.6-34.8). My 31's new measured 30.7 after 50% they're probably 30". I replaced my sagging front springs and oddly they lifted my truck to the point that my Dshaft was 1" too short (max slip on yoke) and threw my wheel 1/4 turn off. It sits level now, but she needs new tires and I want 35" KM2 on 6" springs. I just need to be 100% sure it'll still fit w/o airing down or ratchet straps lol. Btw nice power wagon looks like a beast.
Old Apr 13, 2012 | 01:59 AM
Moparfever4ever
Btw, if you have a dbl door and your measuring w/ the truck in the center make sure your garage roof/frame isnt sagging and throwing the measurement off. 1" sag is hard to visually see and 1" could make or brake me situation. My truck is a vandal magnet w/ fresh paint/ tinted windows/ alpine head unit/ fiberglass R/T hood/ ect. I've never had a problem but thats cuz its sat in a garage. Naturally of course lift and tires will make it even more high profile.
So I appreciate the help guys.
Old Apr 13, 2012 | 04:40 PM
Comrade General
Thanks
I cannot measure as of now because I am nowhere near my truck, but my clearance lights are stock as far as I know. Teardrop design. So my guess is the best I have at the moment.
I dont rub although with some hardcore off-roading porbably so. Its daily driver use for me with fun and some mud now and then nothing too serious. My fenders are also trimmed somewhat which may be the main reason I dont rub but I think ever if they werent a 4'' would be fine but even the slightest off roading would bump.
No spacers and not sure the backspace for the wheels. I run BFG AT. As your last comment mentioned, they arent exactly 35" closer to 34"
Old Apr 16, 2012 | 03:49 AM
Moparfever4ever
No one else has a lifted 1st gen? I find that hard to believe...
