dual alternator setup
Old Apr 22, 2012 | 05:27 PM
Dre20xl's Avatar
Dre20xl
Default dual alternator setup
Im trying to do a dual aternator setup on my 87 d100. It got the 318 in it and i already have the extra alts, tools, time, and skill i just need to know how. I know it has to have been done before but i cant find any info or a how to, can someone help or point to someone who can?
Old Apr 22, 2012 | 05:32 PM
crazzywolfie's Avatar
crazzywolfie
what type of how to info are you wanting to know. are you looking for wiring diagrams on how to hook up a second alternator?
Old Apr 22, 2012 | 06:37 PM
Dre20xl's Avatar
Dre20xl
Yes, im lost when i get to the volt regulators
Old Apr 22, 2012 | 08:02 PM
crazzywolfie
it is a lot simpler than you would think. this picture explains most of it but instead of taking power directly from the battery you have to find something that only has power when the ignition is in the run position. that wire that is labled 12v has to have positive power or you could kill the voltage regulator.
Old Apr 22, 2012 | 10:20 PM
Dre20xl's Avatar
Dre20xl
I know how the basic setup works, does that mean all i have to do is run the wires from the 1st alt and 2nd alt to the same volt reg or will i need a 2 regulators?
Old Apr 23, 2012 | 08:43 AM
SEAL's Avatar
SEAL
With the two alternators are you going to run 1 battery or two? What is the reason for two alternators? What are your power requirements?
Old Apr 23, 2012 | 09:13 AM
crazzywolfie
i would say if you are going to run 2 alternators you will need 2 voltage regulators.
Old Apr 23, 2012 | 02:01 PM
Dre20xl's Avatar
Dre20xl
So 2 alts and 2 volt reguators, how do wire that? Will splicing in the 2nd volt reg. confuse them and stop both of them from working right?
I have 140amps of audio alone and a lot of lighting along with some other things. 1 100amp alt is not fully charging 3 batteries, ive been putting them on a charger at night.
Old Apr 23, 2012 | 02:14 PM
crazzywolfie
you might be able to wire both alternators to share positive ignition power line with the current alternator but the other wire will have to be separate. you also have to make sure the voltage regulator is bolted to a good ground connection.
Old May 10, 2012 | 09:51 PM
RDStuart's Avatar
RDStuart
I would be interested in seeing a picture of the dual alternator bracket/set-up, I have been toying with the idea for a while. I am running three 1000 amp batteries with a isolator due to a heavy draw with my winch it has its own to isolated from the truck because it would stall upon a heavy winch load. works great with the extra two batteries but would like to run dual alternators.
