1991 dodge W150 dome light
Old May 3, 2012 | 09:24 PM
MNfarmboy's Avatar
MNfarmboy
Default 1991 dodge W150 dome light
I need some help. My son purchased a 1991 dodge W150 4x4 and the light around the key switch and the dome light does not go off when the doors are closed. He does not drive everyday and the battery is slowing draining.
Does someone have a wiring diagram and some helpful hints as to where to start looking? On the drivers side the door switch has two wires and the passenger door switch only has one wire.
Any help is appreciated.
Old May 3, 2012 | 09:34 PM
crazzywolfie's Avatar
crazzywolfie
have you check to see what light bulb is in the dome light. if you stick the wrong one in i know it will stay on. should be a 1004
Old May 4, 2012 | 06:45 AM
SEAL's Avatar
SEAL
The door switches provide the ground for those lights. They are a known problem so I would start there. I can't seem to get the wiring diagram to paste here but if you will PM me your email address I will send it to you.
Old May 4, 2012 | 09:36 AM
SEAL's Avatar
SEAL
You can remove the bulbs if you want. This will allow you to use the vehicle without draining the battery until you find the problem.
Old May 4, 2012 | 05:42 PM
crazzywolfie
could also make sure the dimmer switch is not turned all the way until it clicks. someone might have turned them on and forgot how to turn them off.
Old May 5, 2012 | 09:31 AM
MNfarmboy's Avatar
MNfarmboy
crazywolffie, embarassing but true. Seal, thanks for your willingness to help and quick responses.
I didn't think to ask my son and when we were picking up parts for another issue we were asking for some tips on where to look for ground troubles. The guy gave some suggestions and mentioned the dimmer switch as part of the conversation and it didn't hit me until we got home that I should ask my son to try rotating it. He looked at me and said "huh?" He didn't even know that rotating the switch dimmed the instrument panels or would turn on the dome light, map light, and key light.
Dang kids, had to teach him what an LP was too!
Thanks all!
Old May 7, 2012 | 09:55 PM
bigBonehead's Avatar
bigBonehead
If you really want to confuse him... show him a cassette tape and a pencil and ask him what they have in common...
