Odometer not working - clarification
Been searching and need some clarification. On my 92 W150 the speedometer works but odometer does not. I thought both the speedometer and odometer are controlled by the speed sensor in the side of the transmission. But just read on this forum that the odometer is controlled by a sensor in the top of the differential and the speedometer is controlled by the speed sensor in the trans. Can someone please clarify this. No mention of this in the repair manual I have.
if you can find one at a junk yard that works it might be cheaper than fixing the current one. seems to be a common problem.
http://wiki.dieseltruckresource.com/wiki/Odometer_Fix
http://www.speedometergears.com/chrysler-odometer-gears
