my truck idle fing in park but dies when put in gear
(my check engine light and brake light stays on don't know if that means any thing)
Here you go...this will also show you not only how to retrieve them but to read\count them.
http://minimopar.knizefamily.net/fault/index.html
Here for code 25:
http://minimopar.knizefamily.net/fault/code25.html
For code 46:
http://minimopar.knizefamily.net/fault/code46.html
For code 46:
Here for code 25:
For code 46:
For code 46:
the sensors are there for a reason. if they are not hooked up or working properly you can get some strange results. i disconnected 1 of the sensors on the throttle body of a 3.9 once, reved the engine and flames came shooting out the throttle body.
witch sensor did you disconnect that made it shoot flames out the throttle body because i was look at the throttle body the other day nd found a sensor Connecter unconnected
i got the truck to idle in gear after putting a new map sensor in it but know it back fire i have a sensor unpluged buck dont know were it is
