my truck idle fing in park but dies when put in gear
Old Aug 7, 2012 | 10:10 PM
  #31
patrick 1988 dodge's Avatar
patrick 1988 dodge
Originally Posted by patrick 1988 dodge
sorry for not getting back with by ill will find out what the color the wires are latter today
what does the oil pressure sensor look like and were is it location
Old Aug 7, 2012 | 10:52 PM
  #32
crazzywolfie's Avatar
crazzywolfie
Old Aug 13, 2012 | 06:07 PM
  #33
patrick 1988 dodge
it looks like it would go plug in to it but wear is it located at
Old Aug 13, 2012 | 06:12 PM
  #34
crazzywolfie
just below the distributor on the passenger side.
Old Aug 14, 2012 | 11:40 AM
  #35
patrick 1988 dodge
ok im going to go look for it ill give you a up date if i find it
Old Aug 14, 2012 | 01:19 PM
  #36
patrick 1988 dodge
i look but couldnt find it
Old Sep 18, 2012 | 10:13 PM
  #37
patrick 1988 dodge
i was driving down the street and it stalled and wouldnt start up i got it home and tryed to jump it and found that it has no spark turns over but no spark what could it be
Old Sep 19, 2012 | 06:45 AM
  #38
SEAL's Avatar
SEAL
The computerized ignitions are very sensitive to low voltage. Fully charge the battery before condemning the problem as a no spark issue.
Old Sep 19, 2012 | 10:18 PM
  #39
patrick 1988 dodge
could it be a bad battery because i charge it and still no spark put my charger on it and put it to jump star it but still no spark could it be a bad computerized ignition also it backed fired then shut off and now this what could it be
Old Sep 19, 2012 | 10:36 PM
  #40
crazzywolfie
can you hear the fuel pump kick on when you first turn the key to the run position?
