my truck idle fing in park but dies when put in gear
Old Sep 19, 2012 | 11:03 PM
  #41
mastermates's Avatar
mastermates
Originally Posted by patrick 1988 dodge
yeah im going to change them out maybe it the proublm one way to find out
YOU MAY HAVE water in the distributer cap . I have had this problem many times!
Old Sep 20, 2012 | 02:16 PM
  #42
patrick 1988 dodge's Avatar
patrick 1988 dodge
theirs no water at all it happened out of now where
Old Sep 20, 2012 | 02:20 PM
  #43
patrick 1988 dodge
can you hear the fuel pump kick on when you first turn the key to the run position?
no you cant hear the fuel pump kit on when i first turn the key to the run position and i turned it to the run position the get a 12volt jumper and touck the positive wire on the ignition coil and then and only then can you hear the fuel pump go on
Old Sep 20, 2012 | 02:23 PM
  #44
crazzywolfie's Avatar
crazzywolfie
sounds like your asd relay may be bad or is not getting power when you turn the key on.
Old Sep 21, 2012 | 05:24 PM
  #45
patrick 1988 dodge
in the picture it shows 5 prong and i only have 4 but i dont think thats it could it be the ignition switch
Old Sep 21, 2012 | 05:32 PM
  #46
patrick 1988 dodge
what else could it be i has to be something simple
Old Sep 21, 2012 | 05:42 PM
  #47
crazzywolfie
as long as 87a is the only terminal that is not there you are good. did you test to see if there is power at at the relay? it could be as simple as something not getting power.
Old Sep 22, 2012 | 06:02 AM
  #48
SEAL's Avatar
SEAL
Patrick; You have asked for help. CW has given you the best advise based on what you have told us. It is up to you to do the work and actually test the ASD relay. Trouble shooting is a process where you check things in a logical order and in this case that means testing the relay.
Old Sep 26, 2012 | 05:51 PM
  #49
patrick 1988 dodge
i checked it and its good i have fuel now but still no spark so what can it be no spark comeing from the ingintion coil and replaced it
Old Feb 21, 2025 | 09:06 PM
  #50
Bob B-250's Avatar
Bob B-250
Originally Posted by weedahoe
Welcome to the site
can you adjust your idle with a set screw
U can but back it off all the way and then turn 2 1/2 turns or adjust at 700 rpms with vaccum guage , make sure you diconect the temp cool sensor and check all vac lines behind carb or throttle body and make sure youre timing is correct with a timing light
