1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Ok I replaced the 1st piston, rebuilt the head, replaced and checked vacuum lines, replaced iac valve, cleaned and swapped some injectors. I finally got the truck to idle and run but now when I switch gears it gets all jumpy, jerking around, I'm not sure of what to do, any suggestions would greatly be appreciated.
