Booster or Master Cylinder or Both?
Old Aug 15, 2012 | 10:47 PM
RonsBlackRam's Avatar
RonsBlackRam
Default Booster or Master Cylinder or Both?
Hi all. I'm new here and to Dodge. I bought a 1992 D250 5.2 4x4 a couple of days ago after my wife's 96 Bronco kicked the bucket. I'm having an issue with the brakes. They seem to stop OK but with having to apply a little more pressure than what I think would be normal. There is also a hissing coming from under the dash where the brake goes thru the firewall. Also there is a leak on the backside of my master cylinder.
I know I should go ahead and replace the master cylinder but my question is would the hissing be caused by a bad booster also or could the hissing be something else?
I've also checked the check valve and hose for leaks and didn't find any.
I have another question. I just checked my VIN and it says that it is suppose to have a 5.9 360 in it but the PO told me that it was a 5.2 318. How can I visually tell the difference so I know what I have?
Thank you for any help
Old Aug 17, 2012 | 06:51 PM
jasonw's Avatar
jasonw
Site Moderator
https://dodgeforum.com/forum/dodge-r...s-section.html
Old Aug 18, 2012 | 05:31 PM
wontacceptthis's Avatar
wontacceptthis
I am pretty sure that is a booster issue. Obviously the MC needs replaced, but I think with the weak booster will just result in weak assist. Of course, don't trust your wife's life on me saying "I think". As for the engine, I think on the driver's side of the block, there may be some casting info.
Old Aug 19, 2012 | 08:31 AM
RonsBlackRam
I went ahead and replaced the booster and mc. It feels like a different truck now. Hell, I'm just happy not to hear the hissing in the cab any more.
Old Aug 19, 2012 | 09:19 AM
Scooter78's Avatar
Scooter78
One of few visual differences that I know of between the 5.2 and 5.9 is the harmonic balancer (dampener). on the 5.9, there should be a groove or a notch in the balancer. Groove/notch is not present on 5.2 harmonic balancer. Glad your brakes are back up to par. I always laugh at people that cut me off and think, "You really trust the brakes on this 34 year old, 6000k lb truck?! Lol!"
