Plenum
Old Aug 26, 2012 | 07:04 PM
Birge's Avatar
Birge
Default Plenum
Well did the hughs plenum upgrade with the aluminum plate
Now I throwing code 11 anyone else ever see this. Not sure that I disturbed the crank sensor. Quite frustrating
Old Aug 26, 2012 | 09:07 PM
crazzywolfie's Avatar
crazzywolfie
have you looked for any pinched wires? does it run?
Old Aug 27, 2012 | 08:34 AM
Birge's Avatar
Birge
Default no
CW,
No it won't start just cranks away. I have looked over everything for pinched wires. I did find where I think the coil wires Green with Orange stripe had a nick, and the white wire was broken off at the plug, I beleive I have fixed this, but the engine still cranks over and doesn't start. DOesn;t even try.
I am geting fuel, but not getting spark. It throws three codes 12, 11, and 55. I have reached back and checked the connection at the crank sensor but it al lseems to be connected.
I am wondereing if perhaps I don't have the intake tight enough. Inch pounds is goofy, I even spent the extra money on a torque wrench as mine would not go down below 20 ft lbs.
My plan is to double check the torque sequence tonight, and give a thourough look over for pinched wires. I am also looking for a new plug to the coil.
Any other thoughts?
Birge
Union MO
Old Aug 27, 2012 | 09:33 PM
Birge's Avatar
Birge
Ok I'm a dumb *** I did pinch a wire and I addressed the coil wires with a plug in from a junk yard, it fired right up. But I think I still have some more work to do when it's light out again thanks cw for the heads up about a pinched wire it only takes one
Birge
Union
MO
Old Aug 27, 2012 | 09:53 PM
crazzywolfie
glad you got it all sorted out. i know pinched wires seems to be a common problem when working on something so big with so many wires.
